Activities
- Overview
- UI Automation
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- SY-USG-013 - Private File Invoke
- SY-USG-014 - Incorrect Execution Template Placeholders
- Applications and technologies automated with UI Automation
- UiPath Browser Migration Tool
- Computer Vision Recorder
- Click
- Hover
- Type Secure Text
- Send Hotkey
- Type Into
- Check
- Select Item
- Select Multiple Items
- Get Text
- Set Text
- Activate
- Highlight
- Set Focus
- Anchor Base
- Context Aware Anchor
- Find Relative Element
- Indicate On Screen
- Element Exists
- Find Element
- Wait Element Vanish
- Find Children
- Get Ancestor
- Element Scope
- Get Attribute
- Set Clipping Region
- Get Position
- Take Screenshot
- Wait Attribute
- On Element Appear
- On Element Vanish
- Click Text
- Hover Text
- Find Text Position
- Get Full Text
- Get Visible Text
- Extract Structured Data
- Text Exists
- Click OCR Text
- Hover OCR Text
- Get OCR Text
- Find OCR Text Position
- Microsoft OCR
- Microsoft Azure Computer Vision OCR
- Tesseract OCR
- Google Cloud Vision OCR
- OCR Text Exists
- Click Image
- Hover Image
- Find Image Matches
- Image Exists
- Find Image
- Wait Image Vanish
- On Image Appear
- On Image Vanish
- Load Image
- Save Image
- Attach Browser
- Close Tab
- Go Back
- Go Forward
- Go Home
- Inject JS Script
- Navigate To
- Open Browser
- Refresh Browser
- Set Web Attribute
- Attach Window
- Close Window
- Get Active Window
- Hide Window
- Maximize Window
- Minimize Window
- Move Window
- Restore Window
- Show Window
- Export UI Tree
- Invoke ActiveX Method
- Inject .NET Code
- Click Trigger
- Key Press Trigger
- Click Image Trigger
- System Trigger
- Hotkey Trigger
- Mouse Trigger
- Get Event Info
- Monitor Events
- Get Source Element
- Replay User Event
- Block User Input
- Use Foreground
- Callout
- Copy Selected Text
- Get From Clipboard
- Set To Clipboard
- Close Application
- Open Application
- Start Process
- Get Password
- Tooltip
- Click Picture on Screen
- Click Toolbar Button
- Read Statusbar
- Select Dates in Calendar
- Select Menu Item
- Expand Tree
- Call Transaction
- SAP Logon
- SAP Login
- Table Cell Scope
- SAP Session Attributes Change Trigger
- Expand ALV Tree
- Expand ALV Hierarchical Table
- Use Application/Browser
- Check App State
- Check/Uncheck
- Click
- Extract Table Data
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Keyboard Shortcuts
- Navigate Browser
- Select Item
- Take Screenshot
- Type Into
- Get Attribute
- Get Browser Data
- Set Browser Data
- Mouse Scroll
- Inject Js Script
- Drag and Drop
- For Each UI Element
- Application Event Trigger
- Click Event Trigger
- Keypress Event Trigger
- Set Text
- Check Element
- Fill Form
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Mobile Automation
- Release notes
- Project compatibility
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Draw Pattern
- Terminal
UI Automation Activities
Last updated Apr 3, 2024
The Project compatibility section includes the following pages:
